• 18.11.2026, 17:04
josetortola
Saved Aquaero 2002 profiles unusable in 2003 firmware.
Donnerstag, 16. April 2015, 16:25
Hello.
As the title goes, I've just updated to Aquasuite 2015 v6, all my Aquaero 6 Pro settings have gone to the factory defaults while upgrading and after that my saved profiles are not valid for my Aquaero.
Aquasuite displays the message "Data not compatible with this firmware!" when I try to import settings from file. I've tried the four profiles I saved, and allways the same dissapointing result.
Is it possible to convert or use in some way the "old" saved profiles?. If it's not, how can I revert my Aquaero 6 Pro firmware to the previous one?.
Thanks.
Donnerstag, 16. April 2015, 17:35
Your save-file must by corrupted, at least my AE5LE have imported my old profiles fine.(Aquasuite 2015 v4 -> Aquasuite 2015 v6 FW200x ->2003)
josetortola
Donnerstag, 16. April 2015, 17:57
I had four different profiles. Actually, I used all of them. And I saved all of them just a couple of weeks ago with the last thing I updated on them.
Now I can't get any of them imported. I've tried them all.
In this PC I have an Aquaero 6 PRO and a Farbwerk USB version. I haven't tried in other PC that has an AQ5LT, Farbwerk USB and Aqualis reservoir with fill level sensor because I do not want to lost that PC's configurations as in this one.
InfoSeekerX
Donnerstag, 16. April 2015, 20:37
Your best response will be from support@aqua-computer.de
