• 22.11.2026, 22:19
kot0005
poweradjust 3 ultra with Aquaero 6xt
Montag, 20. April 2015, 08:35
Hello, anyone able to help me connect poweradjust to my aquaero?
There were 3 cables in the box. One was usb, one was a 3 pin connector and the last one was a female Molex . So do I just use the 3 pin cable to connect the aquabus plugs on both aquaero and poweradjust ?
Also what's the Molex cable for ?
Cheers ;)
Montag, 20. April 2015, 10:06
Yes, to the high aquabus. For the first set up and possible firmware update you should connect the usb, too(to the motherboard). (if it is´t in the way it can stay connect, too)
Connection cable for Laing DDC pumps
poweradjust 3 FAN>Molex
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »EnigmaG« (20. April 2015, 10:16)
