• 22.11.2026, 21:42
JayCub
NZXT
Mittwoch, 22. April 2015, 22:59
Hi guys could some-one kindly point out the orientation of the usb cable, when attatching to the nzxt expansion hub or to a guide if it is already on here some where
thank you in advance
Tom :D
Railgun
Mittwoch, 22. April 2015, 23:10
With the input facing down, all the grounds are to the left.
JayCub
Brilliant
Donnerstag, 23. April 2015, 11:30
Thank you very much for the diagram, really helpful and I can save the image, this should be a sticky to be honest
Cheers Railgun appreciated
Tom
also can be found on page 6 of the aquero manual, section 3.9
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »JayCub« (24. April 2015, 20:54)
