• 22.11.2026, 23:07
Kaffefilter5
Software Sensors in AquaSuite
Sonntag, 3. Mai 2015, 01:00
So the other day I upgraded windows 8 to 8.1, and installed aquasuite. Everything went perfectly smoothly, except for that nothing shows up when I select data source on any of the software temp sensors. I have tried installing AIDA64, HWiNFO and Open HW Monitor + reinstalling one more time, but nothing appears still. BTW, the temps show up in OpenHWMonitor, so it is not like my MoBo doesnt let software read temps. I have also both reset and firmware updated my aquaero 5 LT, but nothing really happens. I start it as administrator too, so that should not be any problem. Everything else on the aquaero works perfectly though, so i have no idea what it is.
Thank You in advance
Sonntag, 3. Mai 2015, 01:37
Have you setup both AIADA64 and aquasuite for WMI/windows services?
Here is a thread where I outline the steps necessary to pass information from AIDA64 to aquasuite.
Jakusonfire
Montag, 4. Mai 2015, 07:55
If open hardware monitor is reading values it should work just fine. It doesn't need to be configured like AIDA
It sounds like the Aqua computer windows service. Try un-installing and reinstalling it from the Aquasuite settings tab
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Jakusonfire« (4. Mai 2015, 07:56)
Montag, 4. Mai 2015, 19:50
Indeed, though I believe "Shared Memory Support" is required, so be sure it remains active.
