• 22.11.2026, 21:53
Undesirable
Aquaero 6 Buzzer Changed Volume After Passive Heatsink Installation
Montag, 25. Mai 2015, 03:06
Hi there, my buzzer changed volume after I installed Aqua Computer Passive Cooler for Aquaero 6. Previously, it was much louder, but after I installed the heatsink, the buzzer just makes a slight high-pitched whine (which can't be heard with earphones on and nothing playing) and it also makes a clicking noise at the same time.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Undesirable« (26. Mai 2015, 18:34)
Marucins
Montag, 25. Mai 2015, 21:48
In my case, the sound is identical. With or without heat sink.
Dienstag, 26. Mai 2015, 15:55
It sounds like there is an issue with your aquaero.
Your best route is probably to start a conversation with tech support (for the human test, just add the two numbers)
