• 18.11.2026, 19:45
SimonOcean
Pump adapter for D5 pumps for aqualis base with fill level sensor, G1/4
Sonntag, 26. Juli 2015, 16:25
Does the "Pump adapter for D5 pumps for aqualis base with fill level sensor, G1/4" (http://shop.aquacomputer.de/product_info…roducts_id=2926) include a temperature sensor, in the same way the "aqualis XT 450 ml with nano coating, fill level sensor and LED holder, G1/4" (http://shop.aquacomputer.de/product_info…roducts_id=2917 ) has a temperature sensor incorporated?
Sonntag, 26. Juli 2015, 20:25
Neither has an internal temperature sensor... both have a port to accept an external temperature sensor.
Product No.: 41095
The external temperature sensor input is compatible with all Aqua Computer temperature sensors.
Product No.: 34042
the XT variants feature an electronic fill level sensor with USB and aquabus interface, a programmable alarm output and an external temperature sensor input.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (26. Juli 2015, 20:26)
SimonOcean
Sonntag, 26. Juli 2015, 21:03
Oh, okay. Thanks Infoseeker.
Montag, 27. Juli 2015, 00:41
Well, let me follow up with one caveat... if the level sensor is like the MPS level sensor, a temperature reading will show in the aquaero/aquasuite, but it does not reflect the water temperature of the loop.
Jakusonfire
Dienstag, 28. Juli 2015, 19:04
Yep, like all pressure sensors they have a temp sensor built in but its not very accurate at all. A proper sensor will work far better.
