• 05.10.2026, 14:45
elmuzzy
d5 (non pwm) control via aquero 6
Donnerstag, 6. August 2015, 16:29
Hello, got an aquero 6 and want to control the speed of my d5 pump via aquasuite/aquero 6. Ive got 2 d5s one with a taco signal wire (xspc) and
another d5 without taco wire (alphcool).
Which pump can I use and how to do it?
Sorry if this has been asked before but ive search but nothing pops up.
Thanks.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »elmuzzy« (6. August 2015, 16:30)
Kinsy
Montag, 10. August 2015, 09:19
Whether you use the pump with the signal wire or not, you can control both pumps with the Aquaaero 6.
You will need to switch the output to Power Controlled for the pump with no sensor wire, the other pump you can control with Speed Control or Power control.
I have just fitted a DDC Ultra to my AQ6, all I had to do was cut and solder on a 3pin plug. The speed sensor was on it's own 3 pin plug while the power was off a Molex.
elmuzzy
Montag, 10. August 2015, 17:10
Thanks for the reply. Would the Laing DDC pumps for poweradjust cable do the job instead of cutting an soldering?
