• 29.11.2026, 10:10
[RESOLVED] HWiNFO fail
Samstag, 22. August 2015, 11:58
Couple weeks ago I decided to move from AIDA64 to HWiNFO64.
I was running win8.1/64 & aquasuite 2015-6.
Unfortunately, HWiNFO64 did not show up under the System heading in input select, and the shared memory function was checked in HWiNFO64.
Knowing I was about to move to Windows 10, and hoping the issue would go away, I ignored the problem until I updated.
I have now updated to Win10/64 (not clean install), and aquasuite works fine, but the same issue remains with HWiNFO64.
I have latest HWiNFO64 beta installed:
and Shared Memory Support checked:
yet HWiNFO64 does not list under the System heading when choosing input select:
Any suggestions?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »InfoSeeker« (25. August 2015, 17:49)
Montag, 24. August 2015, 15:35
Open the sensor panel, when this windows is not open hwinfo export no data.
Dienstag, 25. August 2015, 03:41
Thank you for comment.
I made sure hwinfo was not only running, but that the main window was also open... unfortunately that did not seem to correct the issue.
Dienstag, 25. August 2015, 06:50
NOT the Main Window, Click to Sensors! Only in this case sensor data exported.
Dienstag, 25. August 2015, 11:48
:D
Dienstag, 25. August 2015, 13:58
Oooh, nice, that works :)
Thank you.
I will send Martin a suggestion to add to the mouse-over help balloon for the Sensor Window Open at start-up preference, that it that it "must be active to use the export function".
And a comment to correct the spelling ;)
