• 01.10.2026, 18:08
DayRider
Donnerstag, 27. August 2015, 10:37
What do you mean by minimize and maximize the page? Do you open another page inside the software or do you minimize the program itself?
Yes, I minimize and maximize the program's window size. However, I have learned very recently that all I need to do is to resize manually the program's window horizontally a little, and bingo, the information pages properly appear.
DayRider
CaseLabs TH10A (Black) + Pedestal
2x Corsiar 1200i PSU (w/ mini-Commander Link)
Asus Ramage V MOBO
i7-5960X, 3 GHz, L3 20 MB, TDP 140 Watt, 8-core, Hyper-Threading
16GB Ballistix Sport DDR4 2 2.4GHz
2x GeForce GTX Titans
4x Samsung 850 Pro 1 TB SSD Drives
AC6 Pro, 2x PA3 Ultra, Flow and Tube Meters, 1x Farbwerk
2x Aquacomputer D5 pumps with USB
5x OCOOL Radiators + 53 PWM fans
2x ViewSonic V3D245 26inch Monitors
Donnerstag, 27. August 2015, 11:01
OK, thanks for the detailed information. Maybe that will help to get an idea why it does not work correctly for some people.
DayRider
Donnerstag, 27. August 2015, 17:27
It seems as if there is a "page overflow" of some sort occurring--or even improper screen resolution. In any case, I resolved the issue on my end with this work-around.
In the past, I hooked up independently the AC6 with all devices detached, and the Information Pages still did not appear until I performed the work-around. So, thinking that another program had to be affecting the XML file on my CaseLabs TH10A computer, I hooked up the AC6 to the USB port of my laptop, installed the Aquaero software, but the Information Pages still did not appear properly on my laptop's screen.
Thank you for your continuing efforts toward making a good software program great.
DayRider
Asus Ramage V MOBO
DayRider
Video of the Disappearing Information Pages
Donnerstag, 27. August 2015, 21:17
Greetings:
I created a short video that depicts what I see when I first click on the "Information pages" tab, and then what magically appears after I horizontally resize the program's window a little. It does not matter if I start with the program's page maximized or minimized--I never initially see the information boxes. Also notice that after I click on the "Information pages" tab, the "Available screens" area shakes a bit. This continues until I horizontally resize the page.
I hopes that this helps.
Video Link: http://www.screencast.com/t/jyjZvGhQ
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »DayRider« (27. August 2015, 21:21)
DayRider
Asus Ramage V MOBO
Freitag, 28. August 2015, 06:57
i think that help us to find the issue.
What screen resolution you have?
Have you any font scaling other than 100% in your windows setup?
DayRider
RESOLVED: Disappearing Information Pages!!
Freitag, 28. August 2015, 20:23
Greetings:
Your questions concerning my present setup are right on! I checked PC > Control Panel > Display and saw that the display was set at 125%. I changed it to 100%, rebooted the system, and the "Information pages" look proper. I must have changed the original percentage long time ago and had forgotten.
Thank you!!
DayRider
Asus Ramage V MOBO
