• 02.10.2026, 11:04
kdurning
pump question
Freitag, 11. September 2015, 01:05
I have an Aquaero 6xt, 2 poweradjust 3, and 2 Aquacomputer D5 Pump Motor with PWM Input. I am using all the 4 pin fan connections on the Aquero, the poweradjusts were bought to control the pumps. The fan connections on the poweradjusts are 3 pin, can i just change the connector and run the pwm off the 3 pin fan connector of the poweradjusts? If not can I utilize the 2 pin connector on the Aquaero?
edit: part number on the pumps are 41105
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »kdurning« (11. September 2015, 03:23)
Freitag, 11. September 2015, 06:57
No, the outputs ar voltage controlled not PWM.
No, the connector has a dirrerent signal - you can control with this connector LEDs (12V) directly, but no PWM Fan/Pumps.
