• 10.10.2026, 20:59
karoloydi
Can I connect white only LED (not RGB) to farbwerk usb?
Sonntag, 20. September 2015, 09:05
I'm not very satisfied with the white colour of RGB lights. It looks too purple to me. Is it possible to connect a white LED to it? Are they compatible?
hugemon
Montag, 21. September 2015, 04:37
You could connect white LEDs to farbwerk with some soldering and/or clever wiring...
Why don't you adjust RGB outputs to make it white?
If your LED is too purple when R=100% G=100% B=100% then you could decrease R and/or B channel and get more accurate color.
karoloydi
Montag, 21. September 2015, 09:35
You are absolutely right! Before I tried removing a little blue and it looked the same. After your advice I removed quite a lot of blue from the light and now it's quite amazing.
I used those settings if anyone is interested.:
R 33
G 30
B 10
