• 13.10.2026, 13:43
ZGIERA
How could I connect Poweradjust 3ultra and Aquacomputer d5 pump to Aquaero 6XT at the same time?
Donnerstag, 24. September 2015, 18:57
Hi there,
I have AQUAERO 6XT fan controller, 2 poweradjustments 3 ultra and 2 Aquacomputer D5 water pumps
so my question is can I connect one of poweradjustments and one of water pumps to aquaero 6xt at the same time?
how can I connect if yes?
I presume I can use a Y splitter to connect poweradjustment and waterpump to high speed scokcet on aquaero 6xt, because these two things can be connected to high speed socket only.
thanks for your advise
Regards
frank anderson
Freitag, 25. September 2015, 06:11
You can connect all 4 devices to your AQ6 XT, first you connect to the USB then assign each device a unique aquabus address, then you disconnect the USB cable and attach it via the aquabus cable, Aquaero will do the recognize it after. This can be achieved via daisy chaining them or using Y cables.
ZGIERA
Freitag, 25. September 2015, 10:38
That's great, thanks for your help :)
Jakusonfire
Sonntag, 4. Oktober 2015, 10:01
To connect multiple Aquabus devices to the Aquaero I like to use these
http://www.performance-pcs.com/modmytoys…-way-block.html
They are compact and neat and make it easy to add new devices in the future. One cable to the Aquaero high port and then any Aquabus device connects to the board.
ZGIERA
Samstag, 10. Oktober 2015, 13:32
I tried to connect one of my 2 AQUA COMPUTER D5 waterpumps with RPM signal to AQUAERO 6XT high usb port and won't work? I'm wonder myself what's wrong with this connection?
Montag, 12. Oktober 2015, 08:40
Have you changed the aquabus ID numbers for the pump?
If so, have you tried the pumps alone?
Jakusonfire
Donnerstag, 15. Oktober 2015, 11:55
Are they USB pumps or just Vario's with the speed dial in the back? Because the d5 with rpm signal is not the USB.
If they are the USB version, they need to be configured via USB first before the aquaero will operate with them properly
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Jakusonfire« (15. Oktober 2015, 11:58)
