• 01.10.2026, 08:11
7HUND3R
Aquastream Noise.
Dienstag, 6. Oktober 2015, 10:12
Ride my Aquastream yesterday, it makes me put up this noise. It is normal?
http://www.dailymotion.com/video/x38q1jb
Dienstag, 6. Oktober 2015, 16:27
There is too much air in your pump. Also the tubing clearly shows that there is still a lot of air in your loop.
You have a lot of swirls in your aquatube so the air which comes in is also sucked in by the pump again... To deaerate the loop you should let the pump run at a low frequency for a while.
7HUND3R
Mittwoch, 7. Oktober 2015, 00:26
Thanks for the reply. Right now I have the jumper off. so that the pump runs at 49Hz. as I have to put the jumper for the pump to circulate more slowly?
Mittwoch, 7. Oktober 2015, 15:11
If you place the jumper before you start the pump it will only reset the pump to its factory defaults as soon as you start it. If you place the jumper while the pump is running it will enter the deaeration mode which continuously starts and stops the pump.
By default the pump is set to automatic mode which means it will try to run as fast as possible. In your case this is not ideal because of the air bubbles inside the aquatube.
7HUND3R
Mittwoch, 7. Oktober 2015, 22:13
Following the manual. putting the jumper on the jumper 1 2 Turn off the pump 56Hz which is somewhat faster than tending all jumper off (49Hz) now no longer makes me noise.
7HUND3R
Freitag, 9. Oktober 2015, 18:08
Failed to get the air remaining in the pipes.
http://rs17.pbsrc.com/albums/b96/7HUND3R…&h=480&fit=clip
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »7HUND3R« (9. Oktober 2015, 18:19)
Freitag, 9. Oktober 2015, 19:15
You will have to tilt your system to get it out there.
7HUND3R
Samstag, 10. Oktober 2015, 14:41
At the end manage to get most of the air force :)
A question. for it is this hole that has this shutoff valve?
Montag, 12. Oktober 2015, 08:38
That does not look like our ball valve. That opening looks strange to me. Maybe a faulty one where the drilling to mount to valve has gone through the entire fitting.
7HUND3R
Montag, 12. Oktober 2015, 11:14
I have another like that but I also seems odd. I'm not riding that since the trial started and I got scared.
I have some questions about the bomb.
Recomendais I buy this for Aquastream bomb? or ceramic factory and incorporates axes?
http://moddingworld.pt/loja/index.php?id…troller=product
Dienstag, 13. Oktober 2015, 09:10
None of these parts will change anything.
The pump already uses a ceramic axis and the impeller is fixed like the modified one.
7HUND3R
Sonntag, 18. Oktober 2015, 02:25
It is normal for the aquaero regulates the fan me this way? it sounds like if the fan rpm increases pegase as small accelerations.
Dienstag, 20. Oktober 2015, 11:56
The blue line is the rpm signal reported from the fan. Nothing special that it is not flat. Some fans show erratic values especially when the voltage is too low for their internal electronic.
The aquaero works fine: the red line which represents the power at the output is flat.
