• 12.11.2026, 10:40
OddsCrazyStuff
Farbwerk sound sensor cable?
Donnerstag, 22. Oktober 2015, 17:55
I have tried all the 3 software programs that Aquasuit 2015 supports and I didnt find a sensor that gets a lot of fluctuations, nor any programs that seems to able to influence CPU or GPU in that regard.
So then I thought about music, but it seems that's not an option it seems.
Which is why I though about merging these 2 cables:
3,5mm plug into PC, 2-pin into Farbwerk.
In theory so should Aquasuit detect it correctly, since it should not be able to tell whats making the power variation on the cable.
But will it work? And can I ruin the Farbwerk by trying?
Freitag, 23. Oktober 2015, 08:56
There is a small chance that it might work but it is more likely that you will damage the farbwerk and/or your mainboard/soundcard. You would have to take additional care of the electrical bonding.
In short words: NO! NO! NO! ;)
OddsCrazyStuff
Freitag, 23. Oktober 2015, 13:09
That idea is out the window then.
So guess I will just have to find another way to create interesting lighting then.
