• 12.11.2026, 19:30
barfly
Donnerstag, 31. Dezember 2015, 22:08
i cant check as this pc doesn't have the a6 led but whats the purpose of a6/outputs/this device where it shows the 4 farbwerk channels and the a6 rgb?
That's exactly what mine looks like. I use Aquasuite 2015-9. I have a feeling the OP might have a older version.
barfly
Samstag, 2. Januar 2016, 03:14
ive ran into another odd issue,when manipulating the 4 led controllers in the aquasuite,such as color changes,setting triggers then it makes the same changes to all the led controllers.
any ideas?
nm,i deleted/re-added rgb's and it's corrected.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »barfly« (2. Januar 2016, 05:29)
GTXJackBauer
Samstag, 2. Januar 2016, 07:57
any ideas?
You must have put the same LED channels on each controller. Glad its working for you. Just takes time getting used to and learning the software/hardware.
