• 13.11.2026, 08:06
JasonMorris
Flow sensor "high flow USB" G1/4 (53129)
Mittwoch, 6. Januar 2016, 11:52
Hi all,
Does it need to be completely level horizontally or vertically or can I have it at an angle? Also, how much room either side before an angle fitting?
Thanks,
Jason
RE: Flow sensor "high flow USB" G1/4 (53129)
Mittwoch, 6. Januar 2016, 14:12
Hi all,
Thanks,
Jason
1. The High Flow USB flow sensor may be mounted in any orientation, but I have seen it mentioned in the forums that a possible clicking sound from the impeller can be reduced by mounting it in the horizontal plane.
2. The High Flow USB flow meter is a mechanical meter and it does not have any limitations as to fittings applied to it.
JasonMorris
Mittwoch, 6. Januar 2016, 14:41
many thanks.
