• 29.11.2026, 09:53
Enser
Farbwerk only outputting red
Mittwoch, 6. Januar 2016, 23:44
As the subject says, my Farbwerk controller is the non-bt version. Have tried multiple outputs with different Aquacomputer RGB cables and multiple strips and no luck- only getting dim red every time. Using Aquasuite 2015 v9 and its showing up fine with full color wheel in Aquasuite.
Advice would be appreciated.
GTXJackBauer
RE: Farbwerk only outputting red
Donnerstag, 7. Januar 2016, 07:08
Make sure the teeth from your LED cables are piercing in the right place of the LED strips and that the cable is connected correctly to the Farbwerk.
JasonMorris
Donnerstag, 7. Januar 2016, 14:47
I had this and it was down to the contacts not being aligned. Pull it and reseat it.
Enser
Freitag, 8. Januar 2016, 21:51
Will take it out and debug, thanks for the advice!
