• 02.10.2026, 22:03
Focal
Need help setting up my Aquaero 5.
Dienstag, 19. Januar 2016, 13:10
Hello everyone,
I just finished my HTPC bulild. Tried to get my A5 up and running but no luck. The device itself seems to work fine. The pump, the fans, etc. I just can't do (adjust) anything in the Aquasuite 2014.
I also tried to reset the device with a jumper placed on the 8th temp sensor. It looks like the device is reset now, the fans and the pump are running at full blast.
However, the A5 demo page, reads the flow and the fan speeds just fine.
I had a problem with my A5 device when I bought one, sent it back and this one was sent as a replacement. I guess the replacement unit was not brand new, as it reads 125 days uptime.
I don't want to upgrade the firmware yet, I want to try the 2014 Aquasuite first.
I would like to set the pump (Laing 3.25 DDC) and the fans to 50%, monitor the temps and the flow.
Thank you!
And this is the 2015.
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Focal« (19. Januar 2016, 13:54)
Dienstag, 19. Januar 2016, 14:12
you have to use a actual aquasuite version, old versions are not supportet.
Focal
Dienstag, 19. Januar 2016, 14:27
Please explain. https://aquacomputer.de/software.html gives me 2 different versions.Tried them both. Whats the "actual aquasuite version" I have to get and where from?
Kind Regards
Dienstag, 19. Januar 2016, 15:15
you have to use the aquasuite 2015.
Focal
Dienstag, 19. Januar 2016, 15:22
So I have to upgrade the firmware as well to make it work correctly in the 2015?
Without the new firmware the readings are wrong, but my main concern is why can't I see the settings panel for adjustments?
Dienstag, 19. Januar 2016, 15:42
Update the device Firmware!
Focal
Dienstag, 19. Januar 2016, 16:14
Sorted. I was expecting it to work in the older version.
Thanks for your help.
