• 29.09.2026, 03:06
Legolas84
Aquasuite 2015 and mouse problem...
Donnerstag, 21. Januar 2016, 23:39
I just buy Aquaero 6 Pro.
I have a big problem with Aquasuite 2015.
When I open Aquasuite there is a terrible mouse lag. The windows arrow is uncontrollable.
Although aquasuite is open, the mouse works fine in other programs.
My system:
I7 5930K
Sabertooth X99
4x4GB DDR 4 2666
GeForce 980 SLI
Sound Blaster Z
Mouse Razer DeathAdder
Keyboard Logitech G110
S.O. Windows 10 Pro x64
I use Razer Synapse for my deathadder.
The keyboard work fine to write in aquasuite.
I tried without success:
- another mouse logitech
- close razer synapse
- aquasuite run as administrator
- test aquasuite 2014
- disconnect the Aquaero 6 pro USB
- re-install aquasuite 2015
Can someone help me?
barfly
Freitag, 22. Januar 2016, 02:45
you can go into your task monitor and raise your aquasuite.ext I/o priority from low to normal and this should fix the lag,however once you reboot it will revert back to low.
downloading a program called ''prio''will keep this process saved for you.
Legolas84
Freitag, 22. Januar 2016, 09:44
The priority of aquasuite.exe is already normal. I tried to lift up to "real time" but the problem remains :(
Legolas84
Freitag, 22. Januar 2016, 15:47
OK, for all with the same problem.
This problem is related to NVIDIA G-Sync
if you set the G-Sync only for full screen aquasuite works well. But if you set the G-sync for full screen AND window aquasuite have mouse lag problem.
bye.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Legolas84« (22. Januar 2016, 19:27)
Legolas84
Freitag, 22. Januar 2016, 19:27
UPDATE previous post
barfly
Freitag, 22. Januar 2016, 22:03
the ''cpu priority is always set to normal but the i/o priority is set to below normal but setting this process to normal cured my lag,along with an 8 second delay between clicks.
Legolas84
Samstag, 23. Januar 2016, 11:25
Where to find the setting for I / O?
However, what I wrote above solve the problem :)
