• 13.11.2026, 04:55
alfredolo
laing pump stop working
Dienstag, 26. Januar 2016, 11:55
Hello,
i have buyed a new Acquero 6 XT. It work well.
I have connected a Laing DCC pump 18W to Fan1 header with PWM at 40%. The pump run at 660-700 rpm and it is quiet and cold.
Sometimes I see that the RMP go to zero for a few seconds, then pump restart a high speed and readjusts to the correct speed in 1 or 2 seconds.
I checked aquiasuite but there is no RPM graphic. The voltage graphics seems to te correct, a horizzontal line to 11.9V. Fan amplifier 1 is 26 degree, so no temperature problem.
How can i check it the problem is the pump or the acquero ?
Thank you
Jakusonfire
Dienstag, 26. Januar 2016, 12:09
Are we talking about a PWM DDC or a Voltage controlled?
700 rpm is excessively low speed for a water pump like the DDC so if that is correct something isn't quite right.
Some pictures and screenshots always help.
alfredolo
Dienstag, 26. Januar 2016, 12:33
Thank you for reply.
Laing DCC-1plus T 12V 18W. The pcb was broken, i replaced it with this one : http://www.diyinhk.com/shop/ddc-pump/41-…red-mcp355.html
Now the pump is PWM and it seems to work good.
The controller of aquasuite is set to PWM.
I have created a new controller for FAN1 with preset value at 40%, so the pump run at 12V with 40% PWM.
Max pump speed at 100% PWM - 4500rpm
Pump speed at 40% PWM - 750rpm
Jakusonfire
Mittwoch, 27. Januar 2016, 04:19
Oh OK that would explain it then. The standard DDC don't spin that slowly.
I would have to guess that the pump now has a very truncated PWM response curve (even more than the standard is) so that 40% PWM must be close to the absolute lowest speed and the pump is for some reason cutting out, the Aquaero detects that and applies full power to get it spinning again.
Maybe try just running a higher min PWM
Kyle XY
Samstag, 20. Februar 2016, 21:36
For example, the lowest speed I reached with my PWM Laing DDC is around 1270 rpm. Fortunately, if you try to put a 0V signal, it leads to full speed and then, to a check to do because 4500 rpm is audible.
