• 16.11.2026, 00:01
barfly
aquasuite q
Mittwoch, 23. März 2016, 03:07
i just upgraded to the latest software but have a couple of issues
i run the software on a separate monitor,before it used to load to that screen but not now.,as i have to drag it over.
another issue is the aquasuite loads to the initial blank screen and i have to click on the arrow to the top left,wait,then select the profile i want to display where as before it would automatically load the last screen.
any ideas as no start up selections helps.
Mittwoch, 23. März 2016, 13:04
When the aquasuite display page is properly set to display on the desktop, there is no dragging possible.
I believe you may be talking about the aquasuite main program, but it should not be open during normal operation.
Maybe if you posted a screenshot of what it is you are dragging, and also one of the page where you are clicking the top left arrow.
barfly
Mittwoch, 23. März 2016, 22:47
heres the screen,i didnt have to drag it before,it would open from my secondary screen on boot.
»barfly« hat folgendes Bild angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »barfly« (23. März 2016, 22:49)
Donnerstag, 24. März 2016, 11:47
If you have something like DisplayFusion for multiple monitors I believe you can determine which monitor a program opens on.
I prefer the aquasuite program to open on my main mopnitor, but I have the aquasuite desktop display set on my 2nd monitor.
To load a particular page at startup, you can instruct aquasuite to do so:
- select the Overview page tab you want to load on startup,
- click on the gear icon and check "Load page automatically"
Then if you want that page to display on the desktop, click on the monitor-w/arrow icon and aquasuite will place the display on your desktop as per your design.
The Lock icon must be locked.
