• 12.11.2026, 22:31
Dundys
Created page loading issue
Montag, 4. April 2016, 17:04
I created new page in aquasuite, information that will be helpful to me while on desktop e.g. flow rate, hot/cold water temperatures ext.
I selected to load the page automatically I presume it should load with windows, the aquasuite loads, but not the created page, also I had the padlock unlocked when i made the changes and saved them, then locked it, when aquasuite loads on windows startup the page it's not loading onto my desktop I have to go and keep on do that manually :(
I have try different combination, no uck.
Would someone help me to figure this out, please.
Thanks
Dieser Beitrag wurde bereits 8 mal editiert, zuletzt von »Dundys« (4. April 2016, 17:13)
Dundys
Montag, 4. April 2016, 17:34
Solved.
For future reference, for anyone with similar glitch, check/uncheck the "load automatically" box several times , close and reopen aquasuite, that did the trick, at least for me.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »Dundys« (4. April 2016, 17:46)
