• 10.10.2026, 14:20
XenoMorpH
Open Hardware monitor in aquasuit 2016-4?
Dienstag, 12. April 2016, 23:38
It seems that the Open Hardware Monitor sensors are no-longer availabvlein Aquasuit? I am not able to select the data source within the Overview pages, even when OHM is running in the background.
Running Windows 10, AS2016-4
RE: Open Hardware monitor in aquasuit 2016-4?
Mittwoch, 13. April 2016, 04:29
I downloaded and installed OpenHardfwareMonitor, and aquasuite sees it just fine (WIN10/64 & aquasuite 2016-4)
I noticed the most recent OpenHardwareMonitor version is 0.7.1 Beta from December 30, 2014.
You may be better served using HWiNFO (free)
XenoMorpH
Donnerstag, 14. April 2016, 09:50
Seems that NONE of the sensor software (AIDA, HWinfo, etc) shows up under System?
Will do a complete Aquasuit reinstall again....mayvbe that'll help.
EDIT: Nope, still not working. Even with older versions of Aquasuit :(
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »XenoMorpH« (14. April 2016, 10:39)
psychotik2k3
Freitag, 11. November 2016, 00:24
I got the same problem.
I have aquaero taht could read cpu and gpu temperatures from open hadware monitor (0.7.1) and today i launch it and impossible.
when i look on data sources for temperature ou other data the aquasuite does not see open hardware at all...
psychotik2k3
Freitag, 11. November 2016, 00:25
Ok installed latest version 0.8 of open hardware and it works again....
strange.
