• 29.11.2026, 02:47
barfly
aida 64 issue
Freitag, 6. Mai 2016, 17:58
im using aquasuite software with aida software and upon starting things up within a few minutes my aida sensors quit being read by aaquasuite
sometimes aquasuite will eventually reset and begin working again but sometimes not
any ideas?
tia
RE: aida 64 issue
Freitag, 6. Mai 2016, 21:42
any ideas?
tia
Is AIDA64 using Shared Memory or WMI to communicate with aquasuite?
Might try swapping between the two, to see if that helps..
barfly
Samstag, 7. Mai 2016, 00:16
both of those are checked and swapping them to and fro crashes aida64
Samstag, 7. Mai 2016, 16:02
mhmm... I swapped between WMI & Shared Memory in AIDA64 without crashing issues.
If you have both activated, the only thing I can think off is to deactivate one and see if that helps.
Personally, I prefer Shared Memory because I believe it to be faster than writing to, and reading from disk.
Do you have a Corsair AX---i PSU with CorsairLink installed?
barfly
Sonntag, 8. Mai 2016, 21:25
no corsair link,no aisuite or fan controllers
deselecting either WMI or Shared Memory crashes aida64.
Montag, 9. Mai 2016, 07:45
WMI is also located in RAM. But WMI needs significant more cpu performance than Shared Memory.
Montag, 9. Mai 2016, 13:43
Thank you for the clarification Sebastian... greatly appreciated.
barfly
Montag, 9. Mai 2016, 17:43
i have a 5930k w/32 gig memory,neither should be an issue.
Dienstag, 10. Mai 2016, 00:34
Perhaps to try uninstall/reinstall AIDA64?
Or install HWiNFO and see if you have the same result?
barfly
Dienstag, 10. Mai 2016, 04:47
i have used hwinfo without any issues,i also should point out i also have a 4930k w/32 gig ram with the exact issues,
Lazran
Mittwoch, 11. Mai 2016, 20:08
I had trouble with Aida64 as well. Switched over to HWinfo64 and have been problem free ever since. Plus HWinfo64 is free :)
GTXJackBauer
Donnerstag, 12. Mai 2016, 01:52
+1 Same here.
