• 23.11.2026, 00:19
Nihil Simile
Aquareo 6 XT
Mittwoch, 1. Juni 2016, 20:18
It says can control 3 RGB Leds, but I only see one header for the RGB Led. So do you need to make a Y connector or three way connector?
Mittwoch, 1. Juni 2016, 20:30
It can control 3 LEDs but not 3 RGB LEDs. You could use every single channel for a single LED. Connecting more is not possible because it would overload the output.
Nihil Simile
RGB
Mittwoch, 1. Juni 2016, 22:45
Thank You, I see now an RGB when all colors are on is the same as 3 leds.
