• 02.10.2026, 00:59
MP7
Aquastream Ultimate minimum speed?
Mittwoch, 20. Juli 2016, 20:43
Hello again forum, it's been some time... :)
That new Aquastream Ultimate pump seems really awesome but is it true the minimum speed that can be set is 3000 rpm?
Thx
Donnerstag, 21. Juli 2016, 12:55
3000 rpm is the lowest possible speed. below this speed the pump make more noise and the vibrations.
MP7
Donnerstag, 21. Juli 2016, 17:34
I see, I'm asking because I'm running my D5 PWM(with aquaero) on only 10% which according to aquaero spins the pump at 2100rpm, giving my loop about 96,5 l/h.
I can do more actually at 50% it's about those 3000rpm, but after that at higher speeds it gives me bubbles on the bay res.
This pump is interesting because I could remove the flow meter and even a temp sensor since the pump already has both of them inside, and judging by a review I watched yesterday noise level is pretty much the same as D5, I will give it some more thought.
Thx Seb
Donnerstag, 21. Juli 2016, 19:57
you cant compare the speed. the aquastream has an complete different flow/pressure characteristic.
MP7
Donnerstag, 21. Juli 2016, 20:41
Yes it crossed my mind, thought you might give some compare info, at least approximately, flow D5 at 2000rpm vs AU at 3000rpm
I'm using one of yours D5's
