• 29.11.2026, 09:10
Observation re High Flow USB & aquasuite
Montag, 17. Oktober 2016, 14:08
I am currently flushing some new radiators and have a simple loop consisting of 2 D5 USB pumps and a High Flow USB flow sensor.
The two pumps show power & RPM under their respective USB>configure tabs, and I remember the MPS flow 400 also shows the flow rate under its USB>Configure tab.
But the High Flow USB has no indication of the flow rate it detects... I have to build a display page to monitor it.
Just appears lacking to me.
GTXJackBauer
RE: Observation re High Flow USB & aquasuite
Dienstag, 18. Oktober 2016, 00:43
[attach]5791[/attach] [attach]5792[/attach]
Once I installed my flow meter, I was having issues getting any readings in Aquasuite while it worked on the AQ6 itself. That was taken care of with a simple restart of the PC.
Hope the same works out for you.
Dienstag, 18. Oktober 2016, 03:45
I believe the output of the flow sensor may not be shown on the configuration tab because there is really nothing to configure, and the value was either neglected or ignored.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »InfoSeeker« (18. Oktober 2016, 03:47)
