• 13.11.2026, 14:28
Nitromad
advice please. new build
Freitag, 21. Oktober 2016, 09:34
Hi all :)
some history before I get into why I'm here.
I building my first water cooling system but I have ordered a unusual case its a Vector Desk Case. my display cards are pre made GTX 1070 water cooled (x2).
so I would need CPU block ,pump ,Res and rads .advice I would like is I want to use the aqua computer 6 system but I done some research about the Res with fill sensor from what I can find its hit and mix if sensor works if res is mounted horizontal ??
I plan to run 2 or 3 res (just to fill the space mainly) ,not sure if I should run CPU and GPUs on same loop or have 2 loops ?
as every part of system will be on display how tidy looking would system be with all the sensors ?
lastly what items would I need if I did use the aqua computer 6 ? stuff like flow ,temp ,fill sensors
thank for reading :)
Gavin
Samstag, 22. Oktober 2016, 01:45
A fill sensors works by detecting the pressure of the water column.
The problem with a horizontal reservoir is that the water column is very short.
Additionally, the orientation of a reservoir with a builtin level sensor is important because if it is rotated so that the level sensor is at the high side, there will be no water column to detect.
It is probably doable, but you have to understand the physics involved to make it work.
Having one or two loops is more an aesthetic issue than a technical one.
If you want multiple coolant colors, then a dual loop may be the ticket, if not, the a single loop will suffice.
But it looks like a Vector Desk deserves all the bling it can get :)
Hopefully you could tuck the sensors somewhat out of the way.
It all depends on how creative you are and how much work you are willing to do.
If you have a single loop, then one flow sensor and one temp sensor would be sufficient.
You would also need at least one pump per loop.
A fill sensor is not really required to monitor your loop, you will notice fluid loss anyway.
That Vector Desk is impressive, but it will be complicated and you will have to go high end to do it properly.
For instance hard tubing is almost a must, soft tubing will not do it justice.
Just wondering if it may be better for you to do a regular water cooled unit first.
Not to throw cold water on your plans, and wishing you the best, but there is a learning curve involved.
Nitromad
Samstag, 22. Oktober 2016, 10:36
Hi thanks for the reply.
this not my first custom build :) just first build on this scale :)
i will be using hard pipe :) ive already used about 2m worth praticing my bends.
as you said the desk deserves bling hence questions IE: fill sensor and loops if i use the aqua computer 6 i want it to show stuff that it can do.
apart from the temp sensors does location of flow sensors etc matter where in the loop they are ? as the case has a rear compartment that i plan on blacking out to hide stuff ,there be two rads in there and power unit so far. i have a pair of "show" rads on side mounts so there be 2 rads per loop. yep i desided to go two loops :) not sure on colors theme is black/blue.
last question for now :) would one D5 pump work per loop as above ? (2 rads 1 cpu|2 rads 2 gpu) plus sensors)
once again thank you
Gavin
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Nitromad« (22. Oktober 2016, 10:43)
Samstag, 22. Oktober 2016, 15:19
Firstly, I have to retract my statement that a reservoir with a built-in level sensor may work in the horizontal position.
The sensor has to be below the lowest part of the reservoir and that is not really possible if it is built in.
Flow sensor placement/location does not matter.
As water doesn't really compress, the flow rate is constant throughout the loop.
Coolant velocity may vary, but the flow rate will be constant.
I believe one D5 pump per loop should work fine for 2 rads & 1 or 2 water blocks.
GTXJackBauer
Samstag, 22. Oktober 2016, 23:01
I would personally with one single loop but its up to you if you want to go with two loops. A single D5 can power all of that let alone one of the two loops.
