• 12.11.2026, 23:06
Nitromad
aquasuite startup problem.[SOLVED]
Freitag, 18. November 2016, 16:37
Hi all.
im using windows 10 64bit pro but i am unable to get aquasuite to start with windows. the ticked box in program itself .didn't work. i also tryed useing a shortcut in startup folder "in run typed shell:startup" this added aquasuite to list of programs in task manger but still not loading. i am also running as admin.
any ideas ???? :cursing:
thanks
Gavin
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Nitromad« (19. November 2016, 10:39)
RE: aquasuite startup problem.
Freitag, 18. November 2016, 21:39
Hi all.
thanks
Gavin
You have started the aquasuite successfully manually I take it?
Try using Task Scheduler to auto-start aquasuite... "startup folder" is so 1980s :)
Nitromad
[SOLVED]
Samstag, 19. November 2016, 10:19
thanks for reply.
yes i can start aquasuite manually .
unfortunately task scheduler does not get aquasuite to start also :(
any more ideas ?
Gavin
EDIT: it turns out program did not like being run in windows 10 mode. soon as i ran it in windows 8 compatibility mode issue fixed now starts with windows startup. :D
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Nitromad« (19. November 2016, 10:42)
GTXJackBauer
RE: [SOLVED]
Samstag, 19. November 2016, 11:28
thanks for reply.
any more ideas ?
Gavin
Make sure you have the newest running Aquasuite (2016-4).
RE: RE: [SOLVED]
Samstag, 19. November 2016, 12:36
thanks for reply.
any more ideas ?
Gavin
If you got it functioning like you want, then great :)
But aquasuiite auto runs for me with Win10/64 Pro without compatibility mode, so there may still be an underlying issue there.
GTXJackBauer
RE: RE: RE: [SOLVED]
Samstag, 19. November 2016, 12:42
thanks for reply.
any more ideas ?
Gavin
Same here. No issue what so ever and it's running along with HWiNFO64.
