• 23.11.2026, 01:41
SverreMunthe
mps pressure 40
Montag, 21. November 2016, 22:40
Not sure if I've asked it before.
I have an mps pressure 40 connect3ed in parallel with a filter (Aquaero). How does it work? Closing either of the valves on the filter (thus making the same effect as if the filter was clogged) seems to have no effect.
Mittwoch, 23. November 2016, 12:57
Have you done the zero calibration while the pump was turned off? If it was turned on it will not work correctly because when you close the filter you have no flow but the water is still pushed against the filter and also one side of the pressure sensor.
