• 02.10.2026, 19:38
owikhan
new here
Donnerstag, 12. Januar 2017, 05:09
hello
friend,s how i get free license of aquasuite 2017-1.3?
guide me regards
GTXJackBauer
Donnerstag, 12. Januar 2017, 05:25
I'm going by the assumption that you have a Aquacomputer device otherwise you won't be able to use the software.
You go to the download page here and use the top link to install. Make sure to use the drop down to see what other versions you're licensed for.
owikhan
Donnerstag, 12. Januar 2017, 05:32
licensed for 2016-5.3
i want new one and also first time buy this device.I want to learn how i control i7 4790k max ghz and lowest temps
Donnerstag, 12. Januar 2017, 17:02
You have the free version of aquasuite (2016-5.3).
To get version 2017-1.3 you need to own a recently purchased aquacomputer electronic device, or pay a license fee.
Details here
owikhan
Sonntag, 15. Januar 2017, 12:10
how i get maximum speed with use of aquasuite 2016-5.3?
to get more less temps for i7 4790K @4.9GHZ
Sonntag, 15. Januar 2017, 12:30
Aquasuite has nothing to do with getting speed out off a CPU, the Aquasuite controls Aqua-Computer-Devices only.
If you want help, you have to tell use what Devices you have and what your goals are.
GTXJackBauer
Sonntag, 15. Januar 2017, 12:35
Get a better cooler or lower the clocks as those clocks shouldn't be used 24/7 since you're most likely degrading your chips longevity. I would only clock that high for benchmarks and bring it down to a normal 4.4-4.5-4.6, which ever gives you the best temps and lower voltage overall.
What Aquacomputer devices are you using Aquasuite with?
owikhan
Sonntag, 15. Januar 2017, 13:36
how i set maximum pump speed?
Sonntag, 15. Januar 2017, 15:10
apw63
Sonntag, 15. Januar 2017, 17:12
Start here this should answer a lot of your questions I did not make this and its for the Aquaero 5. Most if not all of this still applies to newer aquacompurter components.
My Aquaero 5 Review & Guide & BASIC HOW TO SET UP GUIDE
Montag, 16. Januar 2017, 00:23
If you have the hardware in place and are asking the best way to set up the aquaero, here is one option:
  • set your pump(s) to get the flow rate you are comfortable with (200 to 300 L/H)
  • place a Temperature Sensor (like THIS or THIS) in the water loop to read the water temperature
  • have an Ambient Air Temperature Sensor (like THIS) outside the computer case to read the room (ambient) temperature
  • connect your Radiator Fans to the Fan Ports on the aquaero
  • set up a Virtual Temperature Sensor in aquasuite for the difference between the Water Temperature and Ambient Air Temperature
  • set up a Fan Controller Curve that increases Radiator Fan Speed as the Virtual Temperature (Water-Air) increases
