• 17.11.2026, 08:47
CroyAlore
Aquaero 5 and 6 Display Question
Dienstag, 24. Januar 2017, 10:28
Hello.
I was looking into getting a Aquaero 6 LT. I was wondering if the Aqauero 5 PRO display is compatible the Aquaero 6 LT. And is the Aquaero 5 and 6 displays identical?
Thank you.
willwrk4internet
Montag, 13. Februar 2017, 23:29
I would like to bump this question, because I too am very interested in this.
I noticed in the manual it says that the LT models do not have infrared capabilities, but I don't really care about that.
Otherwise, is it possible to install an Aquaero LT into the LCD display of an XT or PRO model?
Railgun
Dienstag, 14. Februar 2017, 11:12
Given you can retrofit an xt or pro to an LT, yes. It's only firmware that's the real difference. The HW is the same.
Whether a 5 screen will work with a 6 base unit...I've not seen a 5 up close so I can't comment. I have two 6s, one of which I've flipped back and forth to an LT.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Railgun« (14. Februar 2017, 11:13)
willwrk4internet
Sonntag, 19. Februar 2017, 00:29
Actually I think the issue is not in going from a XT to an LT, the question is whether you can put an LT into an XT/Pro screen.
The manual specifically says on p.12 that the LT models do not have infrared receivers. So unless that receiver is part of the LCD screen, I assume that functionality will be lost. Is anything else lost by doing that?
