• 02.10.2026, 12:04
Spacirek
Aquaero breathing output
Samstag, 4. Februar 2017, 02:02
Hello.
I need help before buy. I want to know, if Aquaero 5/6 with Aquasuite, can change power output according to a 'sine' curve??
Example: If I connect 12V LED to 3pin fan header, can I make the LED breathe, or if 3pin fan is connected, can it go from 0% to 100% and back to 0% over time (approximately 3 - 5 sec.)??
I found LED strip, that can be connected to 3pin fan header and brightness can be controlled by fan voltage. And of course, I wanna do breathing light effect :D Maybe the speed of breathing affected by temperature.
If someone can help me, I will be very happy.
Fieldrider
Samstag, 4. Februar 2017, 12:42
I don't know if its possible with the Aquaero and I don't want to force you to buy another device, but with the Farbwerk it would be possible. :)
