• 29.11.2026, 07:53
wa3pnt
Need help with Aquasuite 2017 settings
Mittwoch, 22. Februar 2017, 00:35
I have installed Aquasuite 2017 on a new computer, which has:
Aquaero 6XT
Farbwerk
(2) Aquacomputer D5 Pumps
I'm trying to set up the Farbwerk to control a RGB Strip based on Aquaero Sensor #1 (CPU temp in my setup).
In Aquasuite 2016-4 (which I have on another computer) when I select Aquaero>Outputs I see a section for "This device" and below that a section "farbwerk 1, output1"
In Aquasuite 2017-1.3 I do not have the "farbwerk 1, output 1" section.
What have I not enabled or set up properly?
RodeoGeorge
wa3pnt
Mittwoch, 22. Februar 2017, 01:17
I think I solved my problem.
The Aquabus Cable going to the Farbwerk was unplugged.
I plugged it in, and now have the Farbwerk settings.
RodeoGeorge
