• 03.10.2026, 22:13
HunterVee
aquaero 6 LT PWM ability
Mittwoch, 22. März 2017, 12:51
Hi to all Aquacomputer users,
I am planning my first watercooling system for the next few months and i use a Mini-ITX form factor computer.
As you know Mini-ITX motherboards are a bit more constrict on connections.
I have 4 "PWM" outputs on my motherboard, however, only 2 of them are True PWM, meaning they are capable of PWM signal between 20%-100%, while the other 2 are 4-pin but are really DC regulated than actual PWM capable and thus are limited to a 60%-100% operation range.
I am thus interested in the Aquaero 6 LT USB fan controller, which has all the features i need and i can easily hide inside my Mini-ITX case (NZXT Manta).
In its shop page i see: All fan outputs with 4-Pin plug, switchable between voltage and PWM control.
My question for those whom use it, is it true PWM control like i mentioned above capable of 20%-100% fan curve operation?
Thanks in advanced. :)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »HunterVee« (22. März 2017, 12:52)
Mittwoch, 22. März 2017, 12:54
All 4 fan outputs can operate from 0..100% PWM or as voltage controlled output 0..12V.
HunterVee
Mittwoch, 22. März 2017, 13:41
Thanks sebastian, that answered my question :D
