• 05.10.2026, 14:19
huanghetv
How can display RPM?
Donnerstag, 27. April 2017, 15:00
hello,
Now ,I move my four PWM fan to AQ 6 pro Fan1~4,and use the cable(93111) connect between AQ6:RPM----MB: CPU_Fan.
I want to display the Fan 3 Speed in MB(ASUS) soft, How can I config in aquasuite 2017-1.3?
Freitag, 28. April 2017, 00:34
The RPM port on the aquaero 6 Pro does NOT report fan RPM to the motherboard.
The RPM port generates a fake RPM signal that can be set to zero by by an alarm condition.
If the motherboard supports shutdown on CPU fan failure, then when an alarm condition causes the RPM signal to go to zero, the motherboard would shutdown.
I am not aware of any mechanic where the aquaero can pass fan RPMs to the motherboard.
If you wish to display fan RPMs, you can do so using the aquasuite software.
I believe there is a newer version of aquasuite available
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (28. April 2017, 01:00)
huanghetv
Freitag, 28. April 2017, 01:50
I see. Thank you very much. :)
