• 21.11.2026, 17:01
GAqua
Bug: After Update, Flow Sensor connected on Fan 1 of Aquaero 6 no longer works
Sonntag, 12. November 2017, 02:31
I have an Aquaero 6. I just updated to Aquasuite 2017-3.1.
I backed up my settings and updated the Aquaero firmware after the software update. I loaded the previous settings back.
Now the flow sensor that was attached to fan1 is no longer working. It thinks its a fan again.
Sonntag, 12. November 2017, 03:27
The flow sensor have to be connected to the "aquabus low" port now.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »wpuser« (2. Dezember 2017, 19:57)
GAqua
Sonntag, 12. November 2017, 06:31
Thanks, i'll check that out.
GAqua
Freitag, 1. Dezember 2017, 20:10
The flow sensor have to be connected to to "aquabus low" port now.
This indeed works.
While the notes say that you can still use the Fan-1 port for a flow sensor, this is NOT true. If you only have 2 flow sensors, they have to go to the FLOW port and the AQUABUS LOW ports first.
GTXJackBauer
Samstag, 2. Dezember 2017, 03:03
This indeed works.
That's correct.
