• 13.11.2026, 13:22
jacenty
Aquaero LT 6 problem. Windows 10 - Solved.
Mittwoch, 29. November 2017, 21:17
Hello!
I have a problem with Aquaero LT 6. When I try to connect Aquaero via USB I get a blue screen and "Bad Pool Header" message. Before this I see message "Configuring a new hardware" or something like that. I have Windows 10, mainboard Asus Maximus VIII Gene.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »jacenty« (1. Dezember 2017, 22:43)
Mittwoch, 29. November 2017, 21:37
i think your windows or ar part of your system drivers is broken.
you have to repair your windows.
Try update all drivers, check your bios.
Do not overclock hardware.
CHeck the device with an other computer.
jacenty
Mittwoch, 29. November 2017, 21:46
Oh I see! I overclocked my CPU. Do you thing this is a problem? I'll try to reinstall system. Thanks for the reply. ;)
GTXJackBauer
Donnerstag, 30. November 2017, 05:06
Could be a bad CPU OC. I would follow what Sebastian said and run everything updated and repaired if it needs to be and all on stock settings.
jacenty
Donnerstag, 30. November 2017, 19:47
Should I worry about it? I don't know, what the red light means. I have connected four fans and a temperature sensor. Aquaero works, of course, but I still can't connect aquaero via usb
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »jacenty« (30. November 2017, 19:56)
jacenty
Freitag, 1. Dezember 2017, 22:14
Ok, everything is ok. I did what Sebastian said. I mean repair Windows and upgrade drivers mainboard, and now Aquaero works astonishing well. :)
Thanks for reply.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »jacenty« (1. Dezember 2017, 22:19)
GTXJackBauer
Samstag, 2. Dezember 2017, 03:04
Thanks for reply.
Glad it all worked out. :thumbsup:
