• 29.09.2026, 00:48
aquasuite desktop object placement question
Montag, 18. Dezember 2017, 23:39
Let's say I have 6 objects grouped.
I know I can grab/drag/drop the objects anywhere on the desktop, but is there a way to grab the objects and move them all a SPECIFIC pixel distance?
Dienstag, 19. Dezember 2017, 07:03
no, this is currently not possible
Dienstag, 19. Dezember 2017, 07:20
Thank you.
Freitag, 22. Dezember 2017, 14:48
Rambling thoughts from a user:
If a single aquasuite displayed object is selected, all parameters for that object may be modified. (multi0.jpg)
If multiple aquasuite displayed objects are selected, only the objects size and font characteristics are available for modification. (multi1.jpg)
Perhaps, instead of removing the "Position X Y" data entry line, changing it to a "Relative move X Y" data entry line that would apply the entered X & Y to each selected object's real X & Y.
I would find that very useful for repositioning, and laying out the desktop view of the aquasuite display.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (22. Dezember 2017, 14:59)
