• 11.10.2026, 15:44
sfcxxhim
After Update Firmware All aquabus of Aquaero 6 Pro no works
Mittwoch, 20. Dezember 2017, 19:07
[img]https://scontent.fhkg1-1.fna.fbcdn.net/v/t31.0-8/25542502_10156035944665956_239270550906895915_o.jpg?oh=b6beac543e14adb9355297f67ace4066&oe=5AD14ADF[/img]
Have One D5 Pump and One Flow Sensor Connected to the "aquabus High" Port
After Update Firmware All aquabus no works
i Connected to the "aquabus Low and High" Port one by one also not working....
Please Help Thanks~~
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »sfcxxhim« (20. Dezember 2017, 19:12)
Donnerstag, 21. Dezember 2017, 05:40
If memory serves, after the firmware update you need to shut down the computer, turn off the power supply, and unplug the power supply power lead for a minute or so.
Then reconnect the power supply power lead, turn on the power supply, and restart the computer.
Hopefully that works for you.
Dundys
Donnerstag, 21. Dezember 2017, 05:48
Also, did you update your hardware's firmware
