• 06.10.2026, 08:26
Dried_Yams
Aquaero g xt not seeing MPS 200 through aquabus
Dienstag, 6. März 2018, 08:50
I connected my mps 200 through usb I updated the firmware, then connected it via aquabus and disconnected the usb and it doesnt see it even under the aquabus tab it doesnt see anything ive connected the aquabus to both ports with no success what do I do?
Dienstag, 6. März 2018, 16:21
If you haven't yet since the firmware update, power down the system, turn off the PSU and unplug the mains cable.
Wait at least 1 minute for all components to drain, then plug back in, turn on PSU & start the system.
Dried_Yams
Dienstag, 6. März 2018, 20:03
Ivd tried that as well still nothing
Dienstag, 6. März 2018, 21:45
is the MPS 200 set to aquabus priority?
Mittwoch, 7. März 2018, 15:40
Not necessary (and also not possible) anymore with current firmware.
Since the USB cable has been disconnected afterwards: are you using a 4-pin aquabus cable because only this one will work? If it is a 3-pin cable the sensor would get no power, so USB must stay connected in this case.
