• 07.10.2026, 06:37
Jokrik
Second D5 pump not detected on aquaero 6 xt (aquabus)
Freitag, 23. März 2018, 16:18
Hey
Kinda need advice before I go further with my last option
I have 2x d5 with aquabus connected via splitty9 to "HIGH" slot on aquaero 6 XT getting first time setup via USB
I changed both of the pump aquabus address to 13 and 14 respectively, and yet only address 13 is detected in aquaero tab as aquabus
Wondering what should I try next before I had to go with my last option to drain my loop and replace my "address 14" aquabus cable (this is very troublesome since my loop is complicated and the aquabus cable on the pump is not accessibleunless I drain the loop)
Freitag, 23. März 2018, 20:59
Shutdown the PC and remove the power too for a short while. The aquaero will only search for new devices after a fresh restart.
