• 01.10.2026, 02:57
Tanayu
Aquasuit software installation problem. Need help!!!!
Dienstag, 10. April 2018, 08:34
After I installed a cpu block (Cuplex kryos NEXT with VISION). I can't install aquasuit software it say "Make sure your system time is set correctly" and I already checked my system are set correctly about time and date. How you guys fix this?
Thank you
Dienstag, 10. April 2018, 08:44
your windows timezone settings AND time setting (current time) must match - let windows syncronize your system time.
Tanayu
Dienstag, 10. April 2018, 09:37
I'm already turn on automatic time zone but still have same problem.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Tanayu« (10. April 2018, 09:56)
Dienstag, 10. April 2018, 14:45
It seems you are using a different calendar. The aquasuite and the license server use the Coordinated Universal Time (UTC) so the year must be set as 2018.
