• 15.11.2026, 17:11
I broke aquasuite :/
Mittwoch, 10. Oktober 2018, 23:04
I set some experimental values in making a bar chart that appear to have broken the aquasuite... it just goes away now.
I tried replacing the dot.page file with a backup, but it doesn't appear to read it, and just stays with the one in memory and quits.
I probably have to do a fresh reinstall, but thought I would ask first if there is a command line switch to load a dot.page file from the command line???
It would be useful if one could specify the display page and/or profile to load at startup.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (10. Oktober 2018, 23:07)
Donnerstag, 11. Oktober 2018, 07:13
delete the file:
Quellcode
1
C:\ProgramData\aquasuite-data\aquasuite.xml
then start the aquasuite and delete the faulty overview page.
