• 08.10.2026, 22:20
knacker
3 pin rgb to farbwerk- any ideas
Mittwoch, 17. Oktober 2018, 11:57
I am looking to control all my case leds via my farbwerk- I have glacier cpu & gpu blocks which connect fine but my case leds- Phanteks evolve X has a 3 pin connector for the leds- any ideas how I can connect them to the farbwerk so I can control everything from the same thing
Silky_
Samstag, 20. Oktober 2018, 21:02
I dont believe that it will work as the 4 pin RGB connector is not compatible with such. You might have to pick up a different RGB controller that accepts the addressable RGB or 3 pin connectors. Take a look at the new QUADRO lighting controller. Be sure to ask @Shoggy to get the final word.
