• 05.10.2026, 10:46
Vredezbyrd
Aquasuite not showing all MPS information
Samstag, 17. November 2018, 07:01
Hey guys,
Currently in the process of setting up my loops, running;
2 x Aquacomputer D5 USB/Aquabus interface pumps
1 Aquero 6 XT
Currently have ONE pump plugged directly into the USB 2.0 header on the motherboard so I can address it and tell it to priorities the Aquabus, but for some reason I see none of that information under Configuration in Aquasuite, all I see is Pump Power and nothing more.
I've checked my .NET framework, tried different USB ports on the motherboard and tried reinstalling Aquasuite (2018-8), nothing. Any help would be really appreciated.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Vredezbyrd« (17. November 2018, 07:03)
Samstag, 17. November 2018, 07:54
Everything is right. Under Overview Pages or Quick View you see some more informations about your pump.
Vredezbyrd
Samstag, 17. November 2018, 08:00
Alright, so where exactly do I tell my pump to priorities the Aquero 6 instead of USB?
Vredezbyrd
Samstag, 17. November 2018, 08:18
Figured it all out, all good! Some very old information out there regarding these pumps / aquero.
NRD
Montag, 14. Januar 2019, 09:25
Could you please post how you solved the issue so that people researching your issue in the future can benefit from the information?
Montag, 14. Januar 2019, 14:11
I believe Vredezbyrd may not be back, all 3 of his posts were in this thread.
Are you having an issue?
