• 06.10.2026, 07:48
Maki911
Is it possible to connect two D5 Next pump in serial config?
Freitag, 25. Januar 2019, 05:46
Hi everyone, I've bought two d5 next pumps,and I was wondering can I connect them in serial config? Will that impair sensors function?
II ARROWS
Montag, 28. Januar 2019, 00:29
You should be fine, just don't expect 2x perfomance.
I would have chosen another pump if you need the extra flow, but it should work.
The sensors are independent, they just see the temperature and flow at their point, if they are in serial one directly after the other, you should basically see the same value on both (within measure error).
