Du bist nicht angemeldet.
Revan654
Each device uses different pins to send power and signal to all the devices.But whay aquaero and vision, fabwork to, is not working thru hubby7 and Aq D5 pump works fine?Now i hawe 5 devices from AQ and not inaf interial usb heders .
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bartdude« (15. März 2018, 11:28)
Revan654
I would check your motherboard manual to make sure it matching up correctly. Sometimes there soldered to the board upside down. If you willing I would grab one of these: https://shop.aquacomputer.de/product_inf…roducts_id=3388 to see if it powers up from one your USB front ports. Test both Hubby 7 and AQ6 with it.
Pin alignment is the first thing I checked. USB works fine plugged
into motherboard header without Hubby, doesn't work with Hubby. Pins are
fine! 5 different people couldn't all get it wrong.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Revan654« (15. März 2018, 21:06)
Undesirable
I could also check to make sure the pin is in the USB position. If all that checks out. I would attach a sata cable to the Hubby 7 and switch the pin. Maybe your USB 2.0 header doesn't have enough power for some reason. Is the Hubby 7 lighting up at all?
One other thing what slot are you putting the AQ in on the hubby 7?
It's very likely it's a voltage issue.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Undesirable« (16. März 2018, 00:21)
XXL24H
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »XXL24H« (16. März 2018, 04:59)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bartdude« (16. März 2018, 08:55)
Revan654
It's not that old, I have one attached to i7 2600k.Same reason as you guys, I didn't want to lose my case USB2 plugging in
the Aquaero 6 XT so i got a Hubby7 and everything works fine.
AQ6+PA3+MPS400 all plugged into to Hubby7 and all working in Aquasuite. I
have both USB and Aquabus connected. I have an Asus Rog Maximus VII
Formula+ I7-4790k (I know it's getting old but it's still relevant) The
only other difference is I'm still running the previous version of the
firmware 2017-3.1. I'll update it l8r and see if I have any issues.
It's not a voltage issue, the Hubby lights up fine, other devices work
fine. It's not a pin orientation or misalignment issue. I tested the
Hubby in both SATA and USB mode. I referred to both the motherboard
manual and the Aquaero manual before I plugged any USB cable in, and
visually checked the pins too. I tested the Aquaero on every single
position on the Hubby 7 but Aquasuite just would not detect it.
zouille
Try the Cable on ROG EXT header as well.
Is the device listed in the device manager?
XXL24H
Exactly the same case but i hawe croshair 6 extrime and i using 2 visions moduls, fabwork, D5 and aq 6lt. And yes i using internal adapter from usb 3.0 to 2.0 but its CAN BE PERMANENT SOLUTION FOR ME!
The C6H board have only the ROG_EXT USB 2.0 port ....
For me (C6H) aquaero's (6XT and 6LT, last firmware) are not detected in aquasuite with both HUB's : Hubby7 (with and without sata, jumper correctly selected to the right power,...) and NZXT(with molex connection to power it) but are detected by windows using this soft http://www.uwe-sieber.de/usbtreeview_e.html
the HUB's work well with other stuff : I'm still using them in other PC build : z87 & h57 intel chipset mini-itx board's
When the aquaero's are plugged directly on this USB2.0 internal port, They are correctly detected by aquasuite
Please, don't try to take all people there to be Noob to connect an internal USB 2.0 port.... we are, already, a lot who reported the same issue with the same motherboard since launch
Check this Topic :
Problem mit dem Hubby 7
and sorry for my english![]()
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bartdude« (19. März 2018, 10:28)
It works for me... No issue whatsoever.
I also have a splitter for the USB header ( https://www.moddiy.com/products/10%252dP…able-(5cm).html ).
Aquaero 6.
