• 12.11.2026, 18:31
Crazy-Carl
53068 Flow sensor?
Sonntag, 17. Februar 2019, 23:55
I have a 53068 flow sensor that will be plugged into my Aquaero 6 Pro. The 53068 will be placed further on in my loop just to see how flow rate is away from pump.
Has anyone tried this? I have ordered a D5 Next pump, will it read flow rates correctly?
Thanks;
Crazy-Carl
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Crazy-Carl« (17. Februar 2019, 23:58)
Montag, 18. Februar 2019, 02:26
The D5 Next product description states:
The accuracy does not match the accuracy of an external flow sensor, but is entirely sufficient for monitoring purposes.
Your flow sensor will produce the more accurate results, for what that's worth.
And the flow sensor may be placed anywhere in the loop and it will yield the same result, as the coolant flows at a constant rate throughout the loop.
Crazy-Carl
Montag, 18. Februar 2019, 23:08
Thanks INFO :)
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Crazy-Carl« (18. Februar 2019, 23:12)
