• 06.10.2026, 04:30
formal
Aquaero 6 Pro with dual D5 options
Donnerstag, 28. Februar 2019, 12:08
Hi all, I need to run dual D5 with the Aquaero 6 pro to feed 2x Mo-ra3 radiators, all I need are fan curves, temp in/out sensors and flowrate
Would like to keep as much of this in the Aqua brand as possible for minimal compatibility issues, any pointers would be greatly appreciated
Railgun
Donnerstag, 7. März 2019, 15:18
I run a dual DDC with 21 fans (most being GT AP-15s). What do you need to know?
If you know the specs of the fans, and you already have the specs of the Aquaero, you’ll have all you need to know.
RE: Aquaero 6 Pro with dual D5 options
Donnerstag, 7. März 2019, 21:42
The aquaero 6 Pro will run your fan curves.
The pumps depend on how you want to do it, but with the aquaero, two "Aqua Computer D5 pump motor with PWM input and speed signal" should work well.
Four "Temperature sensor internal/external thread G1/4 for aquaero, aquastream XT and aquaduct", two (1 in/1 out) per Mo-ra.
Two "Flow sensor high flow G1/4 for aquaero, aquastream XT ultra and poweradjust", one for each Mo-ra loop. The aquaero 6 has two flow sensor ports.
